20 years agoFail in run as "Nios II hardware"
Hello, I am using Quartus II 4.2 and Nios II Development kit 1.1. After programming the standard processor, I try to run the C/C++ project into the board. I always obtain the following error: ...
20 years agoTypically I get that message when I have incorrectly assigned my pins and the system is not functioning properly as a result. Are you basing the hardware design off of one of the example designs in the kit or something you have created manually?
