20 years agoFail in run as "Nios II hardware"
Hello, I am using Quartus II 4.2 and Nios II Development kit 1.1. After programming the standard processor, I try to run the C/C++ project into the board. I always obtain the following error: ...
20 years agoWhat board and hardware design are you using?
--- Quote Start --- originally posted by julia@Jun 12 2006, 06:45 PM hello,
i am using quartus ii 4.2 and nios ii development kit 1.1. after programming the standard processor, i try to run the c/c++ project into the board. i always obtain the following error:
"Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused[/b]" Note: I restarted the board many times and always getting the same error. My best regards, Julia <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16136) --- Quote End --- [/b] --- Quote End ---
