20 years agoFail in run as "Nios II hardware"
Hello, I am using Quartus II 4.2 and Nios II Development kit 1.1. After programming the standard processor, I try to run the C/C++ project into the board. I always obtain the following error: ...
20 years agoHi,
I assigned all the pins and I am trying now with the hello world application. It works for sometime and then suddenly it stops working and give me again error: "Pausing target processor: not responding." or "Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x021208B8: does not match ID value does not match: read 0xC34A4322; expected 0xC64D2E14 Timestamp value does not match: image on board is older than expected Read timestamp 15:23:42 2006/06/22; expected 18:22:19 2006/06/22 The software you are downloading may not run on the system which is currently configured into the device. Please download the correct SOF or recompile. Restarting target processor" Thanks, Julia.
