Ethernet performance using TSE in uClinux
Hi all,
I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and barely get up to 12Mbit/s. I did some timings using UDP and a 1024 byte message using a bind()ed and connect()ed socket: Total time to send message (when sendto() or write() is called until it returns): 650us Time spent in the driver (using atse.c driver, altera_tse.c driver gives similar performance): 140us Time in the driver waiting for the hardware to send data: 80us (seems it's doing 100Mbit instead of GbE, but that's a relatively small issue here considering overall performance) Kernel overhead before entering driver code: ~400us Kernel overhead after exiting driver code: ~100us Timing was done by writing to an output pin and using an osciloscope. It seems there's just a lot of overhead using the linux IP stack on the Nios II. Has anybody been able to get better performance or is it hopeless given the speed of the processor?55 Replies
Thank you Kazuyasu and mschnell!
I've made some progress. There was a hardware issue with the SSRAM on our board as well as a Linux issue. With the hardware issue fixed, I was getting an EFAULT ("bad address") trying to send a buffer from SSRAM. It turns out the kernel checks that user pointers are within the program memory in _access_ok in include/asm-nios2/uaccess.h. Adding the SSRAM area to that check fixed the EFAULT problem, but I just went ahead and took that check out. Since I can access all of memory from userspace anyways, it's not really protecting me from anything and the error was a pain to track down.
Putting the buffer in external SSRAM instead of DDR SDRAM got me from 14Mbps to 16Mbps. I then changed the linker script to add an .ssram section and make sure everything else goes in main memory (DDR). diff is attached in case anyone is interested. I then went through the trace of sending a message (17 functions from the system call to the driver for UDP!) and added-#define access_ok(type,addr,size) _access_ok((unsigned long)(addr),(size)) +#define access_ok(type,addr,size) 1
to all the functions. For anyone else trying it who hasn't used attributes before either: that goes right before the function definition like so:__attribute__ ((section (".ssram")))
linux-2.6.x/System.map verifies that they get linked at the right addresses (started on TCP and rx stuff here):__attribute__ ((section (".ssram"))) static int atse_hard_start_xmit(struct sk_buff *skb, struct net_device *ndev) {
(What do those t's and T's mean?) This along with 8k caches got me up to 19Mbps sending 1KB UDP messages. Still dismal for a gigabit connection, but it's an improvement. Unfortunately tightly coupled/internal memory is likely not an option because FPGA resources are limited, but now that I've got this figured out I'll try that once I know if that memory is available. There are still problems though. This configuration only works with kernel debugging enabled. There are three options there that are enabled by default (CONFIG_DETECT_SOFTLOCKUP, CONFIG_DETECT_HUNG_TASK, and CONFIG_SCHED_DEBUG) and if I disable any of them the system doesn't boot with the modified linkage. Also I've double and triple checked the MAC and PHY registers and it seems everything is configured for gigabit, but as my timings in the original post showed, I still seem to only be getting 100Mbps out of the PHY. I'd like to submit/bring up some of these changes to the -devel list but I'm not sure how to make it more general.05000000 T irq_exit 05000088 T do_sync_write 050001ac T vfs_write 050002a8 T sys_write 05000340 t atse_hard_start_xmit 05000684 T sock_sendmsg 0500076c T sys_connect 0500080c T sys_sendto 05000918 T sys_send 05000938 T sys_socketcall 05000b20 T release_sock 05000c3c T dev_hard_start_xmit 05000f00 T dev_queue_xmit 050012ec T netif_receive_skb 0500163c t process_backlog 05001748 t net_rx_action 05001908 T neigh_resolve_output 05001c7c t neigh_timer_handler 05002160 T __qdisc_run 0500249c t dst_output 050024bc t ip_finish_output2 050027ac T ip_queue_xmit 05002be0 T ip_output 05002cb4 T ip_push_pending_frames 05003120 t __tcp_ack_snd_check 050031c0 t tcp_transmit_skb 050039a0 T tcp_connect 05003db8 T tcp_send_ack 05003ea8 T tcp_v4_connect 05004330 T tcp_v4_rcv 05004ae8 T udp_flush_pending_frames 05004b1c t udp_push_pending_frames 05004f90 T udp_sendmsg 050056b0 T arp_xmit 050056c8 T arp_send 05005724 t arp_solicit 050059e4 T inet_stream_connect 05005d44 T inet_sendmsg 05005dc0 t packet_sendmsg_spkt 05005ff8 t packet_sendmsg - Altera_Forum
--- Quote Start --- Hi, I forgot to mention this. Where did you locate the exception hook codes? In the file '/home/***/nios2-linux/linux-2.6/arch/nios2/kernel/head.S', [snip] Kazu --- Quote End --- I haven't modified anything to do with that. I'm not sure what you are suggesting -- putting the exception address somewhere other than 0x20? (which on this system is in DDR SDRAM) - Altera_Forum
--- Quote Start --- I haven't modified anything to do with that. I'm not sure what you are suggesting -- putting the exception address somewhere other than 0x20? (which on this system is in DDR SDRAM) --- Quote End --- Of course, this depends on the MACRO
. If you select the location of exception address in SSRAM with SOPC builder, those scripts automatically set the new address of SSRAM to CPU_EXCEPT_ADDRESS_ASM. So the exception handler is copied to SSRAM. And this is not controlled by linker scripts. If you select the location in DDR SDRAM, it's OK, no problem. --- Quote Start --- (What do those t's and T's mean?) --- Quote End --- Those are 'Symbol Types'. 'T' means that this symbol belongs to 'text' segment and is global. Kazu# if defined(CPU_EXCEPT_ADDRESS_ASM) && (CPU_EXCEPT_ADDRESS_ASM != (LINUX_SDRAM_START + 0x20)) - Altera_Forum
I am currently trying to put some functions in SSRAM on the MMU distribution, but having trouble. I added the section to the linker script as before, but offset for the kernel region:
I then tried adding a couple kernel functions to the section. The results from System.map:NOTES + . = KERNEL_REGION_BASE + SSRAM_BASE; + .ssram : + { + . = ALIGN(4); + *(.ssram) + } + DISCARDS
When I add just do_sync_write, the system hangs after "RPC: Registered tcp NFSv4.1 backchannel transport module." When I add both, I get this at the same place:c04b59ac A _end c5000000 T do_sync_write c5000128 T vfs_write
The address given is not a symbol, which makes me think some data address is getting shifted when I move the functions out of DDR, which makes me think this is a latent problem somewhere, but that's just guesswork. Also, if I use IO_REGION_BASE instead of KERNEL_REGION_BASE, which by my understanding should have the same effect but non-cacheable, I get this link error:r1: c1c16000 r2: 00000000 r3: 00000000 r4: c1c2b620 r5: c1c681e0 r6: 00007e20 r7: c1c16e1c r8: 6f6f7468 r9: 6f6f0000 r10: c1c43450 r11: c1c681e0 r12: 00000000 r13: c1c681e0 r14: c1c43452 r15: 006c6f6f ra: c0072514 fp: c01f8000 sp: c1c16e18 gp: 00000000 ea: c5000128 estatus: 00000001 Unaligned access from kernel mode, this might be a hardware problem, dump registers and restart the instruction BADADDR 0xc4fff891 cause 7 op-code 0x36bdd976fs/built-in.o: In function `vfs_write': (.text+0x2ec8): relocation truncated to fit: R_NIOS2_CALL26 against `do_sync_write' fs/built-in.o: In function `do_sync_write': (.ssram+0xb4): relocation truncated to fit: R_NIOS2_CALL26 against `wait_on_retry_sync_kiocb' - Altera_Forum
--- Quote Start --- When I add just do_sync_write, the system hangs after "RPC: Registered tcp NFSv4.1 backchannel transport module." When I add both, I get this at the same place: --- Quote End --- I figured it out and realized I had the same problem with the non-MMU version: when changing the sections, I have to load in the linux.initramfs.gz image instead of the zImage. The code that loads the image from the link offset is missing code to copy extra sections to the right places. - Altera_Forum
Sorry I'm new to all of this so I have a few questions from all of your threads. 1. How do I compile the kernel with full optimizations? 2. How do I increase cache size? 3. How do I decrease memory latency? 4. How do I enable jumbo frames? I'm using a Cyclone III Starter board with the HSMC-Net daugher card. I have GigE UDP working at the moment, but it's quite slow. I need to increase the speed significantly. I'm connecting the HSMC-Net card to my Macbook directly. Thanks! Benjamin - Altera_Forum
What performance do you expect ? As said in this thread, a NIOS LINUX system will by far not be able to keep up with a line speed of 1 GBit (100 MByte/sec netto) . I doubt even 100 MBit (some 10 MByte/sec netto) performance can be achieved. This system is not viable to do a router kind of application.
-Michael - Altera_Forum
To be honest, it needs to be very fast (> 60 MByte / sec data). We need to send 200 MBytes of data from our board to a PC, and based on the specs we figured GigE was the most versatile and configurable (and also the cheapest).
Will I never achieve that throughput using UDP, Nios II and the TSE core? My understanding was that the TCP/IP component of the Nios Processor was really slow, but that using Jumbo frames and UDP, we could get very high data rates. - Altera_Forum
Not with this CPU alone... Reaching 60MBytes/s with a CPU running at ~100MHz can be a challenge, with any architecture.
You will probably need a hardware acceleration, such as the one in this design example (http://www.nioswiki.com/exampledesigns/nios2udpoffloadexample). Then you can reach speeds close to the theoretical limit, if the target is able to handle it. - Altera_Forum
Pity that there is no demo example for my dev board. I'll try deciphering what they've done....
Thanks for the help and advice.
