17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years agoNot with this CPU alone... Reaching 60MBytes/s with a CPU running at ~100MHz can be a challenge, with any architecture.
You will probably need a hardware acceleration, such as the one in this design example (http://www.nioswiki.com/exampledesigns/nios2udpoffloadexample). Then you can reach speeds close to the theoretical limit, if the target is able to handle it.
