17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years agoI am currently trying to put some functions in SSRAM on the MMU distribution, but having trouble. I added the section to the linker script as before, but offset for the kernel region:
NOTES
+ . = KERNEL_REGION_BASE + SSRAM_BASE;
+ .ssram :
+ . = ALIGN(4);
+ *(.ssram)
DISCARDS
I then tried adding a couple kernel functions to the section. The results from System.map: c04b59ac A _end
c5000000 T do_sync_write
c5000128 T vfs_write When I add just do_sync_write, the system hangs after "RPC: Registered tcp NFSv4.1 backchannel transport module." When I add both, I get this at the same place: r1: c1c16000 r2: 00000000 r3: 00000000 r4: c1c2b620
r5: c1c681e0 r6: 00007e20 r7: c1c16e1c r8: 6f6f7468
r9: 6f6f0000 r10: c1c43450 r11: c1c681e0 r12: 00000000
r13: c1c681e0 r14: c1c43452 r15: 006c6f6f
ra: c0072514 fp: c01f8000 sp: c1c16e18 gp: 00000000
ea: c5000128 estatus: 00000001
Unaligned access from kernel mode, this might be a hardware
problem, dump registers and restart the instruction
BADADDR 0xc4fff891
cause 7
op-code 0x36bdd976 The address given is not a symbol, which makes me think some data address is getting shifted when I move the functions out of DDR, which makes me think this is a latent problem somewhere, but that's just guesswork. Also, if I use IO_REGION_BASE instead of KERNEL_REGION_BASE, which by my understanding should have the same effect but non-cacheable, I get this link error: fs/built-in.o: In function `vfs_write':
(.text+0x2ec8): relocation truncated to fit: R_NIOS2_CALL26 against `do_sync_write'
fs/built-in.o: In function `do_sync_write':
(.ssram+0xb4): relocation truncated to fit: R_NIOS2_CALL26 against `wait_on_retry_sync_kiocb'
