17 years agoEthernet performance using TSE in uClinux
Hi all, I am measuring ethernet performance on a NIOS II based board with an Altera TSE IP Core running uClinux, and it's been disappointing so far. I've done timing using TCP and UDP, and bar...
16 years ago --- Quote Start --- Hi, I forgot to mention this. Where did you locate the exception hook codes? In the file '/home/***/nios2-linux/linux-2.6/arch/nios2/kernel/head.S', [snip] Kazu --- Quote End --- I haven't modified anything to do with that. I'm not sure what you are suggesting -- putting the exception address somewhere other than 0x20? (which on this system is in DDR SDRAM)
