13 years ago
Cyclone3: Flash programmig via JTAG
I’m a student and I started my first FPGA project a few weeks ago. I want to create a “Bootloader” which programs my external flash memory via JTAG. At that point I program my flash memory via Boundary-Scan. But it takes too much time. Therefore I want to speed up the flash programming. I decided to create a Nios system with the embedded Peripherals IP. The “Bootloader” should be downloaded to the FPGA to configure it. Then the “Bootloader” should receive the flash content (program) via JTAG and write it to the flash memory. Could you please guide me through my project at points I don’t get further. Yet, I have less experience with FPGA’s but I’ll do my best.
I have a Cyclone III FPGA Starter Kit for testing. First I want the “Bootloader” to run on the testing hardware. Afterwards, the “Bootloader” should run on another hardware. The major difference among the two hardware is the flash memory.
I want to use Qsys to build the hardware. I think about following components to use:
NIOS II/e : I don’t think I need a cache memory -> simplest processor
JTAG UART : Should connect the host pc with the FPGA via JTAG to send programming data to flash
On-chip (RAM) : 20K on-chip RAM for data and instructions of the NIOS II; data width: 32
Sysid : as a protection
CFI-FLASH : Connection to the external flash memory
Avalon-MM Tristate-Bridge: Connection to the external flash memory
Is anything missing or should I use other components? I attached a screenshot which shows all connections of my system.
Thank you for your help.
Best regards.
    ok dude....
    you need a onchip_ram....... is where your cpu will do the boot....
    reset vector is where your FPGA program will start..... reset vector will set to your flash memory
    exception vector will set to your onchip ram .......is where your cpu boot the nios software
    jtag uart ok!
    good luck
    Franz
    OK. I set the reset vector to cfi_flash.s1 and the exception vector to onchip_ram.s1. The addresses will be automatically set by "Assign Base Address". Consequently I don't change them.
    Then I generate this system. In Quartus project I open a new .bdf, instantiate the block diagramm of my system and connect the Inputs/Outputs (see in screenshot). In addition to that I add the .qip. After that I assign the pins as described in the reference manual (Cyclone 3 Starter Kit). When compiling the design I get "Can't place multiple pins assign to pin location H_3 error. Thus I go to Assignments -> Device -> Device and Pin Options -> Configuration site and select Passive Serial as Configuration Scheme. At the Dual-Purpose Pins site I set every pin to Use as regular I/O. Now I'm able to compile my project.
    Did I miss any step so far?
    Thanks again for your guidance.
    After all these steps I downloaded the .sof to the fpga. Then I started the flash programmer from Nios II Eclipse (the flash programmer dialog box appears).
    I did following steps:
    1. File-> New -> Get flash Programmer details from SOPC Information file
    2. Browse to right .sopcinfo and select it
    3. I checked the values in Connections -> System ID Properties
    4. At Files for flash conversion I add my .sof
    5. Start the Flash Programmer
    But this doesn't work. I get the following error:
    Info: Info: *******************************************************************
    Info: Info: Running Quartus II 32-bit Convert_programming_file
    Info: Info: Command: quartus_cpf --no_banner --convert C:/Users/gger/Desktop/BootloaderTest/Lauflicht/LaufLi.sof C:/Users/gger/Desktop/Bootloader_Files/Projekt_altera/flash/LaufLi_cfi_flash.rbf
    Info: Info: Quartus II 32-bit Convert_programming_file was successful. 0 errors, 0 warnings
    Info: Info: Peak virtual memory: 144 megabytes
    Info: Info: Processing ended: Wed Jul 18 09:34:31 2012
    Info: Info: Elapsed time: 00:00:00
    Info: Info: Total CPU time (on all processors): 00:00:00
    Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
    Info: Resetting and pausing target processor: OK
    Info: Reading System ID at address 0x02011008: verified
    Info: No CFI table found at address 0x01000000
    Info: Leaving target processor paused
    Error: Error code: 8 for command: $SOPC_KIT_NIOS2/bin/nios2-flash-programmer "C:/Users/gger/Desktop/Bootloader_Files/Projekt_altera/flash/LaufLi_cfi_flash.flash" --base=0x1000000 --sidp=0x2011008 --id=0x0 --timestamp=1342588439 --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program
    Do you ever got this error message? Do you know the reason for this error?
    Best regards.
    Ok lets do that.....
    dont use the flash programmer at nios 22 eclipse.....
    go to start /programs /altera /nios2 EDS / nios2 legacy/ nios2 command shell
    and open the nios terminal and :
    sof2flash --input=(your.sof) --output=(output.flash) --offset=(initial offset) --verbose
    your.sof = your project
    output.flash = the file generated
    initial offset = this is the offset of the flash memmory ...this is a data sheet parameter , i use 0x10000 at my flash
    and write your.flash
    nios2-flash-programmer --base=(your flash base addres) output.flash --verbose
    do this and report
    Franz
    Ok, I will try the command shell option.
    I write the commands you told me. But there is an error: "Input file, not found, or is not a valid SOF file"(see in screenshot). I guess the .sof is in a wrong directory. So could you please tell me in which directory the .sof belongs to?
    At the moment I have the following directory structure:
    desktop/Bootloader_Files/Projekt_altera
    -> there are all files (.qsys, .bsf, .qpf, ...) stored
    There are five more folders: .qsys_edit, Bootloader_Altera_E1, db, flash, incremental_db, script
    The .sof I want to write to flash is stored in another directory path:
    desktop/BootloaderTest/Lauflicht
    When I get this error message I copied the .sof from this directory path and paste it to desktop/Bootloader_Files/Projekt_altera, but still the same error.
    Where is the mistake in my actions?
    The offset value should be taken from datasheet, shouldn't it? I'm using 0x10, but the value isn't very important. It is just the offset within the flash where FPGA configuration is to be programmed, isn't it? Thus I can choose a arbitrary address. I start at the lowest programming region (as seen in screenshot).
    Sorry for getting on your nevres :).
    Best regards.
    ok ...good
    looking at the print screen seens to me path error......
    you copied the .sof to specify directory ....at the command shell you need to enter in this directory......type ls and check the files in directory.... and than type the command sof2flash
    my flash not use the first address (0x0 to 0x10000 datasheet)... and my offset need to check 0x10000....
    good luck
    Ok, I did it as you told me.
    First I changed the directory and now the conversion works fine and I get my .flash...
    ...but there is still the "No CFi table found at address 0x01000000" error.
    Thus I checked my base address in Qsys, but it's right. Do you ever get this error message? Do you got an idea how to eliminate it?
    Best regards.
    ok ...please verify the base address at .ptf file
    download the .sof in your board before write
    try erase the flash ...... nios2-flash-programmer --base=(base) --erase-all
    what the cfi_flash do you use?
    rgs
    ok...I've done the erase command after downloading the .sof in my board...but still the same error and the same command shell window message.
    Also I verified the base address in .qsys because I have no .ptf. I think this depends on which tool (Qsys or SOPC) you use...but it should be right.
    I'm using the Altera Cyclone III FPGA Starter Kit...on it a Intel 128P30 (8M x 16) parallel flash. The CFI Core uses default settings for this flash, so parameters concerning the flash should be allright.
    Could this error depend on pin assignment? Maybe we also should take a look at that. Do you ever work with a Dev-Board from Altera? I think my flash should be a 16-bit memory. Thus the Addr[0] is floating.
    It' s so annoying!
    What flash do you normally use?
    Best regards.
