13 years agook ...good
looking at the print screen seens to me path error...... you copied the .sof to specify directory ....at the command shell you need to enter in this directory......type ls and check the files in directory.... and than type the command sof2flash my flash not use the first address (0x0 to 0x10000 datasheet)... and my offset need to check 0x10000.... good luck
