13 years agook...I've done the erase command after downloading the .sof in my board...but still the same error and the same command shell window message.
Also I verified the base address in .qsys because I have no .ptf. I think this depends on which tool (Qsys or SOPC) you use...but it should be right. I'm using the Altera Cyclone III FPGA Starter Kit...on it a Intel 128P30 (8M x 16) parallel flash. The CFI Core uses default settings for this flash, so parameters concerning the flash should be allright. Could this error depend on pin assignment? Maybe we also should take a look at that. Do you ever work with a Dev-Board from Altera? I think my flash should be a 16-bit memory. Thus the Addr[0] is floating. It' s so annoying! What flash do you normally use? Best regards.
