Cyclone3: Flash programmig via JTAG
I’m a student and I started my first FPGA project a few weeks ago. I want to create a “Bootloader” which programs my external flash memory via JTAG. At that point I program my flash memory via Boundary-Scan. But it takes too much time. Therefore I want to speed up the flash programming. I decided to create a Nios system with the embedded Peripherals IP. The “Bootloader” should be downloaded to the FPGA to configure it. Then the “Bootloader” should receive the flash content (program) via JTAG and write it to the flash memory. Could you please guide me through my project at points I don’t get further. Yet, I have less experience with FPGA’s but I’ll do my best. I have a Cyclone III FPGA Starter Kit for testing. First I want the “Bootloader” to run on the testing hardware. Afterwards, the “Bootloader” should run on another hardware. The major difference among the two hardware is the flash memory. I want to use Qsys to build the hardware. I think about following components to use: NIOS II/e : I don’t think I need a cache memory -> simplest processor JTAG UART : Should connect the host pc with the FPGA via JTAG to send programming data to flash On-chip (RAM) : 20K on-chip RAM for data and instructions of the NIOS II; data width: 32 Sysid : as a protection CFI-FLASH : Connection to the external flash memory Avalon-MM Tristate-Bridge: Connection to the external flash memory Is anything missing or should I use other components? I attached a screenshot which shows all connections of my system. Thank you for your help. Best regards.19 Replies
No this should be all you need.
An alternative to the Nios method could be to use an JTAG to Avalon bridge and connect it to the flash controller. Then you could use System Console on the PC to directly access the flash memory using master read/write commands. - Altera_Forum
If you've built a design containing a Nios II processor and a flash controller (as it seems you have) then the nios2-flash-programmer executable supplied with Quartus can be used to program a hex file into your flash
Thanks for your response Daixiwen.
Although I’m very interested in your solution I want first to do it in the described way. Thus I will come back to your solution. But now I didn’t know exactly how to go on. I did the following steps: 1. Connect all components in Qsys as you can see in screenshot I attached 2. Generate this system (no warnings, no errors) 3. Instantiate this system in a .bdf to my Quartus project 4. Connect input-/outputs-pins to the block diagram 5. Add .qip to the project 6. Assign the pins in pin planner 7. Compile my project Is something missing or is it the right way to go on? Then I wanted to use the Flash Programmer from Nios II SBT for Eclipse to write data to flash memory. Therefore I downloaded my project to the FPGA first. After that I started the Flash Programmer and used the .sopcinfo from Qsys. Finally I add my .sof to files for flash conversion and clicked Start. I get the following error message: Error: Error code: 3 for command: $SOPC_KIT_NIOS2/bin/sof2flash --input="C:/Users/gger/Desktop/Quartus_Übungsprojekte/Quartus II/LED_Ansteuerung/LED.sof" --output="C:/Users/gger/Desktop/Bootloader_Files/Projekt_E3/flash/LED_flash_extern.flash" --offset=0x0 Do you have any idea what’s wrong? - Altera_Forum
No I have no idea what an error code 3 is.... I would try to put the sof file in a folder that doesn't have non-ascii chatacters first... maybe the sof2flash binary doesn't like that 'Ü' character in the file path.
Thanls for your advice. But now I get another error message:
Info: No CFI table found at address 0x01000000 Info: Leaving target processor paused Error: Error code: 8 for command: $SOPC_KIT_NIOS2/bin/nios2-flash-programmer "C:/Users/gger/Desktop/Bootloader_Files/Projekt_E6/flash/LaufLi_cfi_flash.flash" --base=0x1000000 --sidp=0x2003008 --id=0x0 --timestamp=1342092177 --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program Have you ever use the flash programmer? Did you recognize any mistakes in my actions? In addition to that I get 4 critical warnings: Critical Warning (332168): The following clock transfers have no clock uncertainty assignment. For more accurate results, apply clock uncertainty assignments or use the derive_clock_uncertainty command. Critical Warning (332169): From altera_reserved_tck (Rise) to altera_reserved_tck (Rise) (setup and hold) Critical Warning (332169): From altera_reserved_tck (Rise) to altera_reserved_tck (Fall) (setup and hold) Critical Warning (332169): From altera_reserved_tck (Fall) to altera_reserved_tck (Fall) (setup and hold) Do you know sth. about that? I don't know where to look. - Altera_Forum
I haven't really used CFI flash chips... But the programmer seems to be looking at the correct place.
Did you create an .sdc file with timing constraints for TimeQuest? You should at least declare your clock inputs so that it can get the internal timing right. Then you'll probably need to constrain the CFI interface too. (and use the derive_clock_uncertainty to get rid of the critical warnings, but don't think those are related to your problem) - Altera_Forum
hi......
if i understand you have a project with soc system running....... you need to write a .sof and .elf in your cfi_flash .....ok??? to write you need to convert the .sof and .elf in .flash files at nios2 command shell and in your project directory you need to do sof2flash --input=(your.sof) --output=(name.flash) --offset=(initial offset) --verbose your.sof = your project name.flash = the file generated initial offset = this is the offset of the flash memmory ...this is a data sheet parameter , i use 0x10000 at my flash and write your.flash nios2-flash-programmer --base=(your flash base addres) your.flash --verbose this write the .flash to convert the .elf elf2flash --after=(your.flash) --input=(your.elf) --output=(nios.flash) --boot=bootLoader_cfi.srec the bootloader file is at your quartus directory -> /altera/11/IP/ALTERA/NIOS2_IP/ALTERA_NIOS2/bootloader_cfi.srec remember to set up your RESET VECTOR in qsys write at nios2 command shel is very fast... cheers Franz - Altera_Forum
Hello Franz,
first of all I'm sorry for the following "stupid" questions :oops:. My intention is to bridge the JTAG interface of the FPGA with the CFI interface of the flash memory. To cut a long story short, I want to create a PFL with a sopc system (in Qsys). Thus I want to write configuration data (.sof) to the flash memory. Every power-on the FPGA should configure from flash memory. But why do I need a .elf? For booting? Your solution sounds quite simple. Could you please explain it more detailed, because I didn't get everything. I would appreciate if you can explain it step by step. I even don't know, how to start the command shell?! I have just one more question. First I have to build a sopc system, generate it and instantiate it (e.g. with a .bdf) in my quartus project. Then I assign all pins, set all Dual-Purpose Pins to regular I/O and set configuration to Passive Serial (to get no "can't place multiple pins assigned to pin location...errors during compilation). Next, I compile my project and donwload the .sof to the FPGA. Now I'm able to program my flash memory with the command shell. Is that all right? Or did I misunderstand sth.? - Altera_Forum
ok dude....
do you want program your external flash ... and use the fpga to do that??? or you want start the fpga with the program in you flash?? you dont need a paralel flash loader... you need to do a sopc with your system :cpu, jtag , tristate bridge, clock, cfi flash , clk_ref.... generate , instantiate, assign, etc.... and compile...... donwload the .sof goes to altera/nios2eds/nios2 command shell at your start menu (windows) and convert the file you want program to .flash and write the flash using nios2-flash-programmer....... i think that ..... explain better what you want to write to the flash...... cheers Franz - Altera_Forum
You're right Franz. First I want to access/program my external flash (read and write operations) and use the fpga to do that. Thus I want to do a sopc.
Because I don't have much experience with sopc and Quartus, I would bid you to guide me through my first project. I think about making the major steps and then asking you if I forget sth. Consequently I would start a new project from the beginning. I think about the components you see in the screenshot I attached. Do I need the onchip_ram or should I delete it? Is the jtag_uart ok or is there a better component for jtag interface? Where should I set the reset vector memory and the exception vector memory? I think about the onchip_ram.s1 or the cfi_flash.s1! I'm very thankful for your help. Best Regards.
