14 years agoCyclone3: Flash programmig via JTAG
Hi, I’m a student and I started my first FPGA project a few weeks ago. I want to create a “Bootloader” which programs my external flash memory via JTAG. At that point I program my flash memory...
14 years agoYou're right Franz. First I want to access/program my external flash (read and write operations) and use the fpga to do that. Thus I want to do a sopc.
Because I don't have much experience with sopc and Quartus, I would bid you to guide me through my first project. I think about making the major steps and then asking you if I forget sth. Consequently I would start a new project from the beginning. I think about the components you see in the screenshot I attached. Do I need the onchip_ram or should I delete it? Is the jtag_uart ok or is there a better component for jtag interface? Where should I set the reset vector memory and the exception vector memory? I think about the onchip_ram.s1 or the cfi_flash.s1! I'm very thankful for your help. Best Regards.
