14 years agoCyclone3: Flash programmig via JTAG
Hi, I’m a student and I started my first FPGA project a few weeks ago. I want to create a “Bootloader” which programs my external flash memory via JTAG. At that point I program my flash memory...
14 years agoThanls for your advice. But now I get another error message:
Info: No CFI table found at address 0x01000000 Info: Leaving target processor paused Error: Error code: 8 for command: $SOPC_KIT_NIOS2/bin/nios2-flash-programmer "C:/Users/gger/Desktop/Bootloader_Files/Projekt_E6/flash/LaufLi_cfi_flash.flash" --base=0x1000000 --sidp=0x2003008 --id=0x0 --timestamp=1342092177 --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program Have you ever use the flash programmer? Did you recognize any mistakes in my actions? In addition to that I get 4 critical warnings: Critical Warning (332168): The following clock transfers have no clock uncertainty assignment. For more accurate results, apply clock uncertainty assignments or use the derive_clock_uncertainty command. Critical Warning (332169): From altera_reserved_tck (Rise) to altera_reserved_tck (Rise) (setup and hold) Critical Warning (332169): From altera_reserved_tck (Rise) to altera_reserved_tck (Fall) (setup and hold) Critical Warning (332169): From altera_reserved_tck (Fall) to altera_reserved_tck (Fall) (setup and hold) Do you know sth. about that? I don't know where to look.
