Patrik78's avatar
Patrik78
1 year ago
CFI 32-bit programming
I'm trying to program a CFI 32-bit flash, composed by 2 16-bit flash in a parallel configuration, , using quartus_pgm/Nios Flash programmer (Quartus 18.1). Flash memories use AMD command set.
I set up a nios2 with a generic tristate controller that seems correctly configured and load at FPGA power on.
In fact the raw CFI table read by the programmer seems to be ok.
Any ideas of why this error is happening ?
Here a screenshot after the command "quartus_pgm --nios2 --base=0x800000 --program" is sent to the shell.
Thank you in advance. 
    • Patrik78's avatar
      Patrik78
      the configuration you suggest is using a max cpld to program the CFI and this is not what I have in my Hardware.
      I've only a Cyclone V connected to the external 32 bit CFI Flash and I would like to program it by Nios Flash programmer.
      Is the 32 bit (16+16) with AMD command set actually supported by Nios Flash Programmer ?
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi
    Happy New Year!
    Do you have any update on this?
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Jingyang, Teh
    • Patrik78's avatar
      Patrik78
      I'm not using PFL, I'm trying to use Nios Flash Programmer.
      Is the 32 bit CFI (16+16 configuration) with AMD command set actually supported by Nios Flash Programmer ?
    tehjingy_Altera
    Hi
    Just to mention if you are trying to run the Nios from a combine 16+16 bit, it is not possible to run the Nios. It can only be run out from one 16 bit CFI.
    For flashing other than the Max10 the CFI will need to be program by an external programmer. Only the Max10 got the CPLD that is able to connect to the CFI.
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Jingyang, Teh
