Patrik78
1 year agoCFI 32-bit programming
Hello, I'm trying to program a CFI 32-bit flash, composed by 2 16-bit flash in a parallel configuration, , using quartus_pgm/Nios Flash programmer (Quartus 18.1). Flash memories use AMD command set....
tehjingy_Altera
1 year agoHi
Have you tried generating the POF according to the how-to link below:
https://www.intel.com/content/www/us/en/docs/programmable/683689/current/programming-70656.html
Jingyang, Teh
- Patrik781 year ago
the configuration you suggest is using a max cpld to program the CFI and this is not what I have in my Hardware.
I've only a Cyclone V connected to the external 32 bit CFI Flash and I would like to program it by Nios Flash programmer.
Is the 32 bit (16+16) with AMD command set actually supported by Nios Flash Programmer ?
