Patrik78
1 year agoCFI 32-bit programming
Hello, I'm trying to program a CFI 32-bit flash, composed by 2 16-bit flash in a parallel configuration, , using quartus_pgm/Nios Flash programmer (Quartus 18.1). Flash memories use AMD command set....
tehjingy_Altera
1 year agoHi
Just to mention if you are trying to run the Nios from a combine 16+16 bit, it is not possible to run the Nios. It can only be run out from one 16 bit CFI.
For flashing other than the Max10 the CFI will need to be program by an external programmer. Only the Max10 got the CPLD that is able to connect to the CFI.
Jingyang, Teh
