13 years ago
Can't ping:TSE+DP83848K+RMII
Dear all,
Recently I debug the board designed by myself. I use dp83848K and take the rmii mode.
I got the rmii to mii code from Daixiwen.
Now I can't ping my board.
I've test the mac_rxd[4..0] and compare the data with wireshark. It is correct,this means data transmit to mac. I'm confused about the interface between rmii_mii model with tse_mac.
https://www.alteraforum.com/forum/attachment.php?attachmentid=7600
https://www.alteraforum.com/forum/attachment.php?attachmentid=7599
https://www.alteraforum.com/forum/attachment.php?attachmentid=7601
https://www.alteraforum.com/forum/attachment.php?attachmentid=7602
https://www.alteraforum.com/forum/attachment.php?attachmentid=7603
Could anyone give me some direction? Thanks a lot!
The message from Nios IDE 12.1:
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Can't read the MAC address from your board (this probably means
that your flash was erased). We will assign you a MAC address and
static network settings
Can't read the MAC address from your board. We will assign you
a MAC address.
Your Ethernet MAC address is 00:07:ed:ff:00:01
prepped 1 interface, initializing...
[tse_mac_init]
INFO : TSE MAC 0 found at address 0x02002000
INFO : PHY National DP83848C found at PHY address 0x01 of MAC Group[0]
INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
INFO : PHY[0.0] - Auto-Negotiation PASSED
INFO : PHY[0.0] - Checking link...
INFO : PHY[0.0] - Link established
INFO : PHY[0.0] - Speed = 100, Duplex = Full
OK, x=0, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x04000203
[tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 192.168.1.234
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
DHCP timed out, going back to default IP address(es)
Simple Socket Server starting up
[sss_task] Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
