13 years agoCan't ping:TSE+DP83848K+RMII
Dear all, Recently I debug the board designed by myself. I use dp83848K and take the rmii mode. I got the rmii to mii code from Daixiwen. Now I can't ping my board. I've test the mac_...
13 years agoI'm confused. Is the problem solved or not? What do you mean by "doesn't display"? Did you set the trigger on m_rx_en? Is it triggering?
