13 years agoCan't ping:TSE+DP83848K+RMII
Dear all, Recently I debug the board designed by myself. I use dp83848K and take the rmii mode. I got the rmii to mii code from Daixiwen. Now I can't ping my board. I've test the mac_...
13 years agoThank you,Daixiwen.
I use signaltap to watch the mac_rxd and mac_rx_dv,but no signal can be captured. So I set these signals to others iOS and watch them by oscillator. The four bits frame are as same as the wireshark's display. Now I don't know how to watch the red in tse or sgdma_rx. I still confused with the 'mac_rx_dv', currently I connect the signal to rx_col in tse_mac. I'm not sure this step. Besides I read the data sheet of DP83848K, it says loop back can be completed by connect rx_dv to tx_en,rxd to Txd. Best regards.
