13 years agoCan't ping:TSE+DP83848K+RMII
Dear all, Recently I debug the board designed by myself. I use dp83848K and take the rmii mode. I got the rmii to mii code from Daixiwen. Now I can't ping my board. I've test the mac_...
13 years ago --- Quote Start --- I have solved the problem.but I can't get the signal by signaltap,maybe my usb-blaster doesn't work well. Thank you again. --- Quote End --- Please what have you did when you have solved the problem? I have similar problem.. My connection of the RXDV is correct.. Thank you for your kind answer.
