20 years ago
build uclinux error
THANKS
I WANT TO DO ACCORDING TO hippo,I downloads the Nios II Linux Distribution v1.4 ,and build.zip.BECAUSE THE NET DOWLOAD IS SLOW,SO I DOWNLOAD THIS FILES:uClinux-dist-20051110.tar.bz2,busybox-20060320.tar.bz2,uClibc-20060320.tar.bz2 AND buildroot-20060320.tar.bz2
,then I place this files in ~/download instead of WGET commond.
COULD YOU HELP HOW TO MODIFY THE BUID FILE:
# !/bin/bash# rm -rf ~/buildroot ~/rootfs ~/linux-2.6.x ~/download/mx140 ~/uClinux-dist ~/apps# to prepare kernel source
cd ~/download
mkdir mx140
cd mx140# convert the crlf with unzip -a
echo "prepare kernel source"
unzip -aoq ../nios2linux-1.4.zip# kernel 2.6.11-uc0 source ported by microtronix
cp -a plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x ~
cd ~/linux-2.6.x
patch -p0 <~/download/kernel.diff
cp ~/download/kernel.config ~/linux-2.6.x/.config# apps ported by microtronix, only Makefile of inetd, ftpd and boa are patched to use the toolchains
mkdir ~/apps
cp -a ~/download/mx140/examples/software/linux/apps/* ~/apps
cd ~/apps
patch -p1 <~/download/mx140apps.diff# to prepare uClinux-dist source
cd ~/download
echo "prepare uClinux-dist source"
wget -N http://www.uclinux.org/pub/uclinux/dist/uc...0051110.tar.bz2 (http://www.uclinux.org/pub/uclinux/dist/uc...0051110.tar.bz2)
cd ~
tar jxf ~/download/uClinux-dist-20051110.tar.bz2
cd ~/uClinux-dist
patch -p0 <~/download/uClinux-dist.diff
touch ~/uClinux-dist/vendors/Altera/nios2nommu/inittab# download buildroot snapshot
cd ~/download
SNAPSHOT=20060320
rm -f buildroot-snapshot.tar.bz2 uClibc-snapshot.tar.bz2 busybox-snapshot.tar.bz2 # wget -N http://buildroot.uclibc.org/downloads/snap...napshot.tar.bz2 (http://buildroot.uclibc.org/downloads/snap...napshot.tar.bz2)# wget -N http://www.uclibc.org/downloads/snapshots/...napshot.tar.bz2 (http://www.uclibc.org/downloads/snapshots/...napshot.tar.bz2)# wget -N http://busybox.net/downloads/snapshots/bus...napshot.tar.bz2 (http://busybox.net/downloads/snapshots/bus...napshot.tar.bz2)
wget -N http://hungryhippo.jot.com/wikihome/buildr...0060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/buildr...0060320.tar.bz2)
wget -N http://hungryhippo.jot.com/wikihome/uclibc-20060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/uclibc-20060320.tar.bz2)
wget -N http://hungryhippo.jot.com/wikihome/busybox-20060320.tar.bz2 (http://hungryhippo.jot.com/wikihome/busybox-20060320.tar.bz2)
ln -s buildroot-$SNAPSHOT.tar.bz2 buildroot-snapshot.tar.bz2
ln -s uClibc-$SNAPSHOT.tar.bz2 uClibc-snapshot.tar.bz2
ln -s busybox-$SNAPSHOT.tar.bz2 busybox-snapshot.tar.bz2
cd ~
tar jxf ~/download/buildroot-snapshot.tar.bz2
cd ~/buildroot
ln -s ~/download dl# patches for configs, add elf2flt to busybox
patch -p0 <~/download/buildroot.diff
make oldconfig
make# clean headers for uClinux-dist
cd ~/buildroot/build_nios2/staging_dir/include/linux
rm config.h autoconf.h
touch config.h autoconf.h# prepare root fs
rm -rf ~/rootfs
mkdir ~/rootfs
cp -a ~/buildroot/build_nios2/root/* ~/rootfs
cd ~/rootfs# remove include and lib to save space# the dev nodes are generated via ~/download/rootfs_list
rm -rf dev usr/include usr/lib# you may use this instead of the one from buildroot
cp ~/download/inittab etc
