20 years agobuild uclinux error
THANKS I WANT TO DO ACCORDING TO hippo,I downloads the Nios II Linux Distribution v1.4 ,and build.zip.BECAUSE THE NET DOWLOAD IS SLOW,SO I DOWNLOAD THIS FILES:uClinux-dist-20051110.tar.bz2,busyb...
20 years ago --- Quote Start --- originally posted by nwpu_zhf2004@May 29 2006, 12:22 PM thanks hippo,because i want to port uclinux to my own board,so i want to according to you, i think the wget in the build script is to download four file ,so i download the four file instead of downloading the four file because the net is slow , do you think so? if so , i want you modify the script ,
by the way, i found that no altera directory in the uclinux-dist\vendors\,why?
thanks!!!!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15644)
--- quote end ---
--- Quote End --- The buildroot process will wget a lot more files. So I don't suggest you run buildroot. (My best suggestion for you) Follow the binary toolchain and uClinux-dist as in nios wiki. You need to download only three files with your browser, http://nioswiki.jot.com/wikihome/operating...ios2gcc.tar.bz2 (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/binarytoolchain/nios2gcc.tar.bz2) http://nioswiki.jot.com/wikihome/operating...ux-dist.diff.gz (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist/uclinux-dist.diff.gz) http://www.uclinux.org/pub/uclinux/dist/uc...0060511.tar.bz2 (http://www.uclinux.org/pub/uclinux/dist/uclinux-dist-test-20060511.tar.bz2) I know the network speed is slow. Please be patient and read some uClinux / Linux doc. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
