20 years agobuild uclinux error
THANKS I WANT TO DO ACCORDING TO hippo,I downloads the Nios II Linux Distribution v1.4 ,and build.zip.BECAUSE THE NET DOWLOAD IS SLOW,SO I DOWNLOAD THIS FILES:uClinux-dist-20051110.tar.bz2,busyb...
20 years ago --- Quote Start --- originally posted by nwpu_zhf2004@May 29 2006, 03:51 PM first i thank you very much,i want do uclinux in my own custiom board,i have not altera dev board,could you give some advice in my own custom board?
thanks!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15649)
--- quote end ---
--- Quote End --- That's OK. First, you should read "before you start" in the wiki http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux) And build your nios2 hardware in sopc builder, compile to sof. The install the binary toolchain (step2) and uClinux-dist (step3). Now you can createt the kernel zImage, and follow the "try out" to run it (step1),
