20 years agobuild uclinux error
THANKS I WANT TO DO ACCORDING TO hippo,I downloads the Nios II Linux Distribution v1.4 ,and build.zip.BECAUSE THE NET DOWLOAD IS SLOW,SO I DOWNLOAD THIS FILES:uClinux-dist-20051110.tar.bz2,busyb...
20 years agothanks hippo,because i want to port uclinux to my own board,so i want to according to you, i think the WGET in the build script is to download four file ,so i download the four file instead of downloading the four file because the net is slow , do you think so? if so , i want you modify the script ,
by the way, I found that no altera directory in the uClinux-dist\vendors\,why? thanks!!!!
