15 years agovlan tagging in ethermac
Hi Folks,
is there any support of vlantagging on the tx-side of the Altera tse-mac, in the featurelist of the userguide (page 8, http://www.altera.co.jp/literature/ug/ug_ethernet.pdf) i find the support of vlan and stacked vlan. in the description of the status/config register I only find registers and signals for VLAN on rx side. Is there any possibility to transmit vlan-tagged frames with ethermac. best regards mooresstudent10 Replies
Yes, you can transmit VLAN frames with TSE MAC. However, there is no "automatic VLAN tag insertion" feature. You have to set your frame up properly (with VLAN tag included) and then ask the TSE to send it. Regards, Franck. - Altera_Forum
Thank you for your reply Franck, it is too simple ;). I am just a ethernetnoob...
Thread can be closed - Altera_Forum
How do you take care of receiving VLAN tagged messages, Franck? Did you modify the driver file (ins_tse_mac.c) to strip the tags before sending the ethernet packet to the nicheStack or added an interface to the tse[iface]? Is there an easy way to do this?
-ravi23 - Altera_Forum
Hi ravi23,
I didn't use the nicheStack nor any IP stack. I used the TSE directly in my logic design so I had no problem handling those VLAN frames..... I can't help you with nicheStack, sorry.... Franck. - Altera_Forum
Franck,
Thanks for your reply. I have another thread in the uC/OS section that may be of interest to you. This is regarding the changes I am making to the drivers / Nichestack for my application. -Ravi - Altera_Forum
--- Quote Start --- Hi ravi23, I didn't use the nicheStack nor any IP stack. I used the TSE directly in my logic design so I had no problem handling those VLAN frames..... I can't help you with nicheStack, sorry.... Franck. --- Quote End --- How did you manage to detect VLAN from the rx_frm_type[3:0] signal in your logic? :confused: I have not found the trick! :( (using full TSE w/FIFO). Want to connect my eth_mon.v to these signals for realtime broadcast filtering and VLAN monitoring. Thank for any tips! mike - Altera_Forum
In the magawizard, make sur you have enabled "VLAN detecttion".
If you are using the small MAC variation, you don't have this option. I don't use rx_frm_type in my design because I'm using the small MAC. However, you can check for the VLAN TAG while receiving the frames to see if it's VLAN.... Franck. - Altera_Forum
--- Quote Start --- In the magawizard, make sur you have enabled "VLAN detecttion". If you are using the small MAC variation, you don't have this option. I don't use rx_frm_type in my design because I'm using the small MAC. However, you can check for the VLAN TAG while receiving the frames to see if it's VLAN.... Franck. --- Quote End --- Franck, Thanks for the reply.... I do have this enabled (thank you). And while I can monitor the VLAN status, the issue is that I need to monitor real-time, frame-by-frame, the VLAN, Broadcast, Multicast and unicast Frame Type status signals provided by the MAC so that I may 'handle' or process them as appropriate for my application. My MAC implementation provides these signals rx_frm_type[3:0] and clearly describes them in the documentation. However a module I have created to monitor incoming packets so far I have been unable 'connect' to these signals. How and What must I do to enable access to these signals (provided by the TSE)? Thanks for your input, mike - Altera_Forum
--- Quote Start --- Hi Folks, is there any support of vlantagging on the tx-side of the Altera tse-mac, in the featurelist of the userguide (page 8, http://www.cusabio.com/pro_7.html) i find the support of vlan and stacked vlan. in the description of the status/config register I only find registers and signals for VLAN on rx side. Is there any possibility to transmit vlan-tagged frames with ethermac. best regards mooresstudent --- Quote End --- Hello! I have another thread in the uC/OS section that may be of interest to you. This is regarding the changes I am making to the drivers / Nichestack for my application. - Altera_Forum
....I looked at your other posts - but could not tell which one you are referring to! ??
