15 years agovlan tagging in ethermac
Hi Folks, is there any support of vlantagging on the tx-side of the Altera tse-mac, in the featurelist of the userguide (page 8, http://www.altera.co.jp/literature/ug/ug_ethernet.pdf) i find th...
13 years ago --- Quote Start --- Hi ravi23, I didn't use the nicheStack nor any IP stack. I used the TSE directly in my logic design so I had no problem handling those VLAN frames..... I can't help you with nicheStack, sorry.... Franck. --- Quote End --- How did you manage to detect VLAN from the rx_frm_type[3:0] signal in your logic? :confused: I have not found the trick! :( (using full TSE w/FIFO). Want to connect my eth_mon.v to these signals for realtime broadcast filtering and VLAN monitoring. Thank for any tips! mike
