15 years agovlan tagging in ethermac
Hi Folks, is there any support of vlantagging on the tx-side of the Altera tse-mac, in the featurelist of the userguide (page 8, http://www.altera.co.jp/literature/ug/ug_ethernet.pdf) i find th...
13 years agoIn the magawizard, make sur you have enabled "VLAN detecttion".
If you are using the small MAC variation, you don't have this option. I don't use rx_frm_type in my design because I'm using the small MAC. However, you can check for the VLAN TAG while receiving the frames to see if it's VLAN.... Franck.
