15 years agoVIP Suite Clocked Video Input/Output Sync Problem
Hi
I'm a newbie trying to use the Video and Image Porcessing Suite with the Altera Cyclone III Development Board (EP3C120F780C7) and the Bitec HSMC DVI interface. I tried to get color bars on a screen with this design : Test Pattern Generator -> Clocked Video Output : it works. The parameters for the CVO are : for 1280x720p@60Hz 1280x720 hor sync. : 128 pixels hor front porch : 64 pixels hor back porch : 192 pixels ver sync : 5 lines ver front porch : 3 lines ver back porch : 20 lines My problem is : I am using the analog interface AD9981 (from Analog Devices) to convert analog video signal to digital video signal. My design is : Clocked Video Input -> Clocked Video Output The AD9981 is configured to work in 720p@60Hz and i keep the same parameters as my first design for the CVO, but I get nothing on screen. It seems that there is a problem with the horizontal sync output : there are only 14 lines for the vertical back porch although I put 20 lines in the "vertical back porch" parameter Can anyone help me please!! Thanks! Dath4 Replies
Hi Dath
You should check about In/Out Vid Clock diffrence. Are you using same clock? If In/Out clock different, It require Frame Buffer in VIP. Good Luck to you!! - Altera_Forum
not an easy task.
Hi dath,
I am trying create Test Pattern Gen -> CVO. I connected vga_clocked_video_vid_clk(clk_25), // vga_clocked_video.vid_clk vga_clocked_video_vid_data(rgb_data), // .vid_data vga_clocked_video_underflow(), // .underflow vga_clocked_video_vid_datavalid(vid_datavalid), // .vid_datavalid vga_clocked_video_vid_v_sync(v_sync), // .vid_v_sync vga_clocked_video_vid_h_sync(h_sync), // .vid_h_sync vga_clocked_video_vid_f(), // .vid_f vga_clocked_video_vid_h(), // .vid_h vga_clocked_video_vid_v() Then assigned it to VGA pins assign VGA_SYNC_n = 1'b1; assign VGA_R = rgb_data[23:16]; assign VGA_G = rgb_data[15:8]; assign VGA_B = rgb_data[7:0]; assign VGA_BLANK_n = vid_datavalid; assign VGA_CLK = !clk_25; assign VGA_HS = !h_sync; assign VGA_VS = !v_sync; But it still didnt work. Can you tell me where I should reconnect? I would appreciate your help!! - Altera_Forum
Frame Buffer is a must in this situation.
