15 years agoVIP Suite Clocked Video Input/Output Sync Problem
Hi I'm a newbie trying to use the Video and Image Porcessing Suite with the Altera Cyclone III Development Board (EP3C120F780C7) and the Bitec HSMC DVI interface. I tried to get color b...
12 years agoHi Dath
You should check about In/Out Vid Clock diffrence. Are you using same clock? If In/Out clock different, It require Frame Buffer in VIP. Good Luck to you!!
