15 years agoVIP Suite Clocked Video Input/Output Sync Problem
Hi I'm a newbie trying to use the Video and Image Porcessing Suite with the Altera Cyclone III Development Board (EP3C120F780C7) and the Bitec HSMC DVI interface. I tried to get color b...
12 years agoHi dath,
I am trying create Test Pattern Gen -> CVO. I connected vga_clocked_video_vid_clk(clk_25), // vga_clocked_video.vid_clk vga_clocked_video_vid_data(rgb_data), // .vid_data vga_clocked_video_underflow(), // .underflow vga_clocked_video_vid_datavalid(vid_datavalid), // .vid_datavalid vga_clocked_video_vid_v_sync(v_sync), // .vid_v_sync vga_clocked_video_vid_h_sync(h_sync), // .vid_h_sync vga_clocked_video_vid_f(), // .vid_f vga_clocked_video_vid_h(), // .vid_h vga_clocked_video_vid_v() Then assigned it to VGA pins assign VGA_SYNC_n = 1'b1; assign VGA_R = rgb_data[23:16]; assign VGA_G = rgb_data[15:8]; assign VGA_B = rgb_data[7:0]; assign VGA_BLANK_n = vid_datavalid; assign VGA_CLK = !clk_25; assign VGA_HS = !h_sync; assign VGA_VS = !v_sync; But it still didnt work. Can you tell me where I should reconnect? I would appreciate your help!!
