16 years agoVIP Control is Mutilating my Image!!!
Hello All,
I have an interesting problem. I've managed to put together a video processing path: cvi->scaler->frame buf->cvo Which works reasonably well scaling SXGA to SVGA for display on an LCD. Very simple. See 1st image below image. i then add a nios2/e with the standard JTAG UART and sysid peripherals. For ease I'm using 4k of on chip ram. I've connected the control port to all the above blocks. For the result look at the 2nd image below. This has only happened since upgrading my Quartus to 9.1. The sp1 upgrade did not fix the issue. It appears that instead of a line of 800 pixels arriving at the cvo, i'm getting 800 + n (where 5 > n > 10). This causes the square to be splayed diagonally. I've built this dozens of times with different size fifos on the cvo/cvi, and I think that my timing constraints are ok. See attached my sopc config. If I reduce the incoming SXGA signal by a few pixels (never consistent between builds) then the image lines up again and looks normal. But resetting the sopc will cause the distortion again. It's like the sopc is auto-detecting x pixels each time it comes out of reset, and then outputting x + n. Another note is that bit 10 of the cvi status register never sets - indicating that a valid resolution is never detected. My HS & VS signals are both logic +ve, and they only occur when the data_valid signal is 0 so they should be disturbing a frame. i've checked the data_valid window against the incoming pixel clock and it measures a perfect 1280px (or what ever I set the video to) and is stable with expected jitter and good amplitude. Has anyone see this issue before? did any of the vip ip blocks change so significantly between 9.0 and 9.1 as to cause this issue? All help greatly appreciated, thanks in advance. Cheers, Brent.
