16 years agoVIP Control is Mutilating my Image!!!
Hello All, I have an interesting problem. I've managed to put together a video processing path: cvi->scaler->frame buf->cvo Which works reasonably well scaling SXGA to SVGA for displa...
16 years agoYou're right. I appologize. I have a spreadsheet that I use for the memory bandwidth calculations but I had it set up for half-rate mode and you're running the controller in full-rate mode. Your bandwidth is 4.8Gbps which at 70% efficiency is 3.36Gbps. Sorry for the confusion.
No I don't work for Altera. Jake
