TTK failed reading from PHY slave
Hi ,
I have generated a design example using low latency ethernet 10g mac intel Arria 10 fpga ip design example user guide. The link to the design example is below:https://www.intel.com/content/www/us/en/docs/programmable/683063/19-1-19-1/quick-start-guide.html
I have compiled the design by giving appropriate pins and while testing on the hardware, the system console is giving error as below.
error:
TTK failed reading from PHY slave_2000, cannot enable TTK functionality for this PHY. Please verify the reconfig_clk is running and ensure this PHY is not stuck in reset."
I ensured that reconfig_clk is set properly and also tried different jtag clock frequencies(24MHz, 16MHz, 6 MHz).
Hi Vamsi,
I already sent the example design to your email and please check your email.
zying
- ZiYing_Intel
Hi Vamsi_21,
Could you try building a simple one channel test design with Native PHY, TX PLL and reset controller and try linking with XCVR toolkit? This would be helpful to narrow down to XCVR channel only.
zying
- Vamsi_21
I have build the design with one XCVR channel only, but it is still showing the same error.
- ZiYing_Intel
Hi Vamsi_21,
Can you try to move away from XCVR toolkit, create signaltap and monitor the TX and RX status to see if they are working fine. Just to isolate any Native PHY issue from XCVR toolkit.
zying
- Vamsi_21
- ZiYing_Intel
Hi Vamsi_21,
I just get to know that the EyeQ is no longer supported in A10 devices. It seems to be due to some issue with the EyeQ result. Please avoid using the EyeQ.
zying
- Vamsi_21
Iam not using EyeQ, instead iam using signal tap logic analyzer to monitor the tx and rx status signals.
- ZiYing_Intel
Hi Vamsi_21,
Can you check how many jtag service ports and what index number of desired port by "get_service_paths master" command in the system console?
This index number is used in the "hwtest/basic/basic.tcl".
zying
- ZiYing_Intel
Hi Vamsi,
zying
- Vamsi_21
Thank you for the design.
- ZiYing_Intel
Hi Vamsi,
Thanks for your reply. I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
zying
