Vamsi_21
2 years agoTTK failed reading from PHY slave
Hi , I have generated a design example using low latency ethernet 10g mac intel Arria 10 fpga ip design example user guide. The link to the design example is below:https://www.intel.com/content/www/...
- 2 years ago
Hi Vamsi,
I already sent the example design to your email and please check your email.
zying
ZiYing_Intel
2 years agoHi Vamsi_21,
Could you try building a simple one channel test design with Native PHY, TX PLL and reset controller and try linking with XCVR toolkit? This would be helpful to narrow down to XCVR channel only.
zying
Vamsi_21
2 years agoHi,
I have build the design with one XCVR channel only, but it is still showing the same error.
