8 years agotiming questions -false path for the experts
I have a design that has value in it that define the code behavior, let call them: config_reg table_of_vaule 1. because of the nature of those things, they are deep in the design. 2. those values are being configured using 25Mhz clock 3. values are used using a 100Mhz clock. I run a set_flase_path : set_false_path -from [get_keepers {config_reg}] set_false_path -to[get_keepers {config_reg}] make sure than when I write and read I hold the values10 clocks, make sure it sticks. Another code run on a different 100Mhz, used config_reg(0) to branch. Assuming values at config_reg are stable does the set_flase_path has any damaging effect? @100Mhz if(a=1 and config_reg(0)) then ... what about that: @100Mhz if(a=1 and config_reg(sel)) then ... where sel and a are 100Mhx values with NO false_path on them. thanks
