9 years agotiming questions -false path for the experts
Hi, I have a design that has value in it that define the code behavior, let call them: config_reg table_of_vaule 1. because of the nature of those things, they are deep in the design. ...
9 years ago --- Quote Start --- If you mean conf_reg is constant then that is not a timing path to reg (a). Now if reg (a) is on slow clk you are sampling a constant (no problem) and (a) will acquire new value. If this is passed to fast clock then this path from (a) must be allowed to settle. You need to explain clocks used in your request of a <= conf_reg --- Quote End --- Hi, I explained it before, but ill do it again: Hi, I have a design that has value in it that define the code behavior, let call them: config_reg 1. because of the nature of those things, they are deep in the design. 2. those values are being configured using 25Mhz clock 3. values are used using a 100Mhz clock. I run a set_flase_path : set_false_path -from [get_keepers {config_reg}] set_false_path -to[get_keepers {config_reg}] *making sure that when I write and read I hold the values 10 clocks (or more), make sure it sticks. Another code run on a different 100Mhz, used config_reg(0) to branch. Assuming values at config_reg are stable does the set_flase_path has any damaging effect? @100Mhz if(a=1 and config_reg(0)) then ... what about that: @100Mhz if(a=1 and config_reg(sel)) then ... where sel and a are 100Mhx values with NO false_path on them.
