G_Sunil_Kumar's avatar
G_Sunil_Kumar
2 months ago
Stratix-10G FPGA Transceiver Configuration for Ethernet MAC 100G Controller
We need to validate our custom built Ethernet MAC 100G controller core on Stratix-10G FPGA. We are planning to use the in-built FPGA transceiver for the PHY functionality.
From the IP catalog, we selected "L-Tile/H-Tile Transceiver Native PHY Stratix 10 IP" and tried to configure for Ethernet MAC 100G. But we couldn't find any preset configuration which supports either 100G or 25G line rate.
Could you pl. suggest what preset configuration to be used? Pl. note that our Ethernet MAC 100G controller core supports 256-bit data path.
Sunil
  • Hello Sunil,
    If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
    Altera Technical Support
    • G_Sunil_Kumar's avatar
      G_Sunil_Kumar
      Hi Pavee,
      Thanks for your support.  If there are any questions related to this in future, will contact support again.
      Sunil
      • paveetirrasrie_Altera's avatar
        Thanks Sunil, Feel free to reach out to us if any support required. Happy to help.
  • Thanks Pavee, will try your suggestion and update how it goes.
    Sunil
        G_Sunil_Kumar
        Hi Pavee,
        Sorry for replying late.  We tried using the E-Tile Transceiver PHY as you suggested. Under preset configurations, we could see the following.
        PMA Direct Bonded 8 channels NRZ 28Gbps DW
        PMA Direct Bonded 8 channels PAM4 56 Gbps DW
        PMA Direct Dual Channel PAM4 56Gbps DW
        We are not sure which one to select. We selected the default one PMA Direct Bonded 8 channels NRZ 28Gbps DW  and proceeded. We have captured the complete transceiver settings in the attached doc. Could you pl. check and let us know if this fine?
        Sunil
