Stratix-10G FPGA Transceiver Configuration for Ethernet MAC 100G Controller
Thanks Pavee, will try your suggestion and update how it goes.
Sunil
- paveetirrasrie_Altera8 months ago
Hello Sunil,
May I know if the suggestion helped?
Pavee
- G_Sunil_Kumar8 months ago
Hi Pavee,
Sorry for replying late. We tried using the E-Tile Transceiver PHY as you suggested. Under preset configurations, we could see the following.
PMA Direct Bonded 8 channels NRZ 28Gbps DW
PMA Direct Bonded 8 channels PAM4 56 Gbps DW
PMA Direct Dual Channel PAM4 56Gbps DW
We are not sure which one to select. We selected the default one PMA Direct Bonded 8 channels NRZ 28Gbps DW and proceeded. We have captured the complete transceiver settings in the attached doc. Could you pl. check and let us know if this fine?Thanks,
Sunil- G_Sunil_Kumar8 months ago
See attached doc for transceiver configuration settings.
