9 years ago
Strange problem with DCFIFO
in my design, I'm using two dual clock FIFOs for buffering. While one is running without any problem, the other one is doing something strange when loading the design to the FPGA (DE1-SoC).
Some details: The FIFO has a writing clock of 25MHz and a reading clock of 143MHz, overflow / underflow protection are enabled and it has a size of 16bit x 512 words. I'm using the rdusedw (named as FIFO_READUSED) port
to generate my own request signal (c_mem_xxx are integer constants)
 signal s_read_used   : integer range 0 to 511;
 signal s_data_request : std_logic_vector (1 downto 0);
(some lines removed)
 --generate DATA_REQUEST signal
 s_read_used <= to_integer(unsigned(FIFO_READUSED));                            <===(1)
 --s_read_used <= 260;                                                          <===(2)
 s_data_request <= "11" when (s_read_used > c_mem_high) else
       "10" when (s_read_used >= c_mem_half) else
       "01" when (s_read_used > c_mem_low) else "00";
The strange thing is, that the simulation runs as expected but when loading the design on the FPGA is behaves strange. I've connected some of the rdusedw signals to the LEDRs on the board as well as my data request signal
to observe them. Now when I'm using line (2), everything is fine. But when I'm using line (1) the FIFO seems to get stuck (the rdusedw signal is stuck at 0 and so does my data_request signal). I really have no idea about the
reasons...
My second FIFO is implemented in exactly the same way with the difference that I'm using the wrusedw signal - and this FIFO is running as expected.
So, does someone have any idea about what's going on here?
I've tried a lot of different things (e.g. removing the integer things and using only unsigned, ...) without finding a solution.
Best,
Martin
    Sounds like a timing related issue - does the design meet timing?
    (2) will work because it is a constant, and hence s_data_request will be optimised.
    Thanks for your reply.
    Yes, I don't have any warning generated by TimeQuest when using the PLL reset sources. When using my reset logic, I get 4 warnings (probably because I haven't added constraints in the sdc file yet).
    However, I observe the mentioned behavioral in both cases.
    Ok, I did some further investigations but still I have no idea why this is happening.
    I don't think that the problem is timing related since I get no message from Time Quest around this part of the design.
    Like written above, I use some of the LEDs of the DE1-SoC board to display the current value of rdusedw.
    When I use this signal in any possible way (like simply forwarding two of the bits), all LEDs stay dark indicating the FIFO to be always empty. But when I remove every line of VHDL code containing the rdusedw signal, the
    LEDs show the current value of elements stored in the FIFO as expected.
    So is there something is miss or do I have to add special Contraints to the SDC file to see if something is wrong with the timing?
    PS: I took a closer look on the RTL schematic and there is nothing between the output register of the FIFO and the input register of my design (when reading the rdusedw inside my clocked process @143MHz)
    Why not post the code/project that exhibits the problem?
