17 years agoSimulation error caused by S-function
I am trying to simulate sample example of DSP builder. But when i start simulation, some errors occured depending on S-function parameters. Here you can find the type of errors seen in Simulink: ------------------------- S-function parameter count mismatch. S-function sInOut in singen/SinIn is expecting 0 parameters while 8 were provided in the dialog box. -------------------------- End error seen in MATLAB: -------------------------- Error in block : singen/SinIn Java exception occurred: com.altera.dspbuilder.simulation.templates.BlockTemplateException: Error creating block template : com.altera.dspbuilder.blockset.iobus.Input at com.altera.dspbuilder.simulation.templates.BlockXMLParser.createBlock(Unknown Source) at com.altera.dspbuilder.simulation.templates.BlockXMLParser.getBlockTemplate(Unknown Source) ..and goes down like that --------------------------- I tried with MATLAB 2007b and 2008b with DSP Builder v8.1, but it doesn't simulate.... I don't get how to I solve this issue and I can't find any related/reported problems on the forum please help Thank you... Enes You can also send your solution directly to my e-mail: [email protected]6 Replies
Can you give the rest of that stack trace? Annoyingly I think the relevant bit may be further down.
This is the result of getting started tutorial of DSPB which is named "singen"
All blocks which are inserted from DSP Builder Library to model file are given following error type => S-function parameter count mismatch. S-function sInOut in singen/SinIn is expecting 0 parameters while 8 were provided in the dialog box Sorry, but I don't understand exactly what you wonder? - Altera_Forum
You said:
--- Quote Start --- Java exception occurred: com.altera.dspbuilder.simulation.templates.BlockTe mplateException: Error creating block template : com.altera.dspbuilder.blockset.iobus.Input at com.altera.dspbuilder.simulation.templates.BlockXM LParser.createBlock(Unknown Source) at com.altera.dspbuilder.simulation.templates.BlockXM LParser.getBlockTemplate(Unknown Source) ..and goes down like that --------------------------- --- Quote End --- I'd like to see the bit replaced by "... and goes down like that" - Altera_Forum
Error in block : singen/BusBuild
Java exception occurred: java.lang.IllegalArgumentException: No enum const class com.altera.dspbuilder.simulation.ExtendedDirection.İNPORT at java.lang.Enum.valueOf(Unknown Source) at com.altera.dspbuilder.simulation.ExtendedDirection.valueOf(Unknown Source) at com.altera.dspbuilder.simulation.templates.BlockXMLParser.addPortToBlock(Unknown Source) at com.altera.dspbuilder.simulation.templates.BlockXMLParser.createBlock(Unknown Source) at com.altera.dspbuilder.simulation.templates.BlockXMLParser.getBlockTemplate(Unknown Source) at com.altera.dspbuilder.simulation.BlockFactory.getBlockTemplate(Unknown Source) at com.altera.dspbuilder.simulation.BlockFactory.getBlockTemplate(Unknown Source) at com.altera.dspbuilder.simulation.Factory.createBlock(Unknown Source) at com.altera.dspbuilder.simulation.Model.createBlock(Unknown Source) at com.altera.dspbuilder.simulation.Cache.createBlock(Unknown Source) at com.altera.dspbuilder.simulation.Mask.updateGUI(Unknown Source) - Altera_Forum
In addition to this, errors are seen in MATLAB command window for each blocks that give S-function error in Simulink
It seems to me that your DSPB installation is corrupt.
The forum is mangling the text a little bit, so I'm not sure. Where it says "No enum const class com.altera.dspbuilder.simulation.ExtendedDirection.INPORT", on my screen the "I" is coming up as either İ or if I change the encoding to an I with a dot above it. Either way this is not good. Can you confirm exactly what the text looks like on your screen. Try manually adding spaces in between each of the words separated by full stops - this should stop the forum doing its own thing.
