17 years agoSimulation error caused by S-function
Hello, I am trying to simulate sample example of DSP builder. But when i start simulation, some errors occured depending on S-function parameters. Here you can find the type of errors seen...
17 years agoIt seems to me that your DSPB installation is corrupt.
The forum is mangling the text a little bit, so I'm not sure. Where it says "No enum const class com.altera.dspbuilder.simulation.ExtendedDirection.INPORT", on my screen the "I" is coming up as either İ or if I change the encoding to an I with a dot above it. Either way this is not good. Can you confirm exactly what the text looks like on your screen. Try manually adding spaces in between each of the words separated by full stops - this should stop the forum doing its own thing.
