17 years agoSimulation error caused by S-function
Hello, I am trying to simulate sample example of DSP builder. But when i start simulation, some errors occured depending on S-function parameters. Here you can find the type of errors seen...
17 years agoThis is the result of getting started tutorial of DSPB which is named "singen"
All blocks which are inserted from DSP Builder Library to model file are given following error type => S-function parameter count mismatch. S-function sInOut in singen/SinIn is expecting 0 parameters while 8 were provided in the dialog box Sorry, but I don't understand exactly what you wonder?
