AAlph's avatar
AAlph
8 years ago
simulate an LVDS soft core IP
Hi everyone
I'am trying to simulate the LVDS soft IP on MAX10 FPGA using modelsim-altera
it works fine with the receiver but when simuling the transmitter i get those errors
Loading fiftyfivenm.fiftyfivenm_ddio_out(behavior)
# ** Error: (vsim-3033) nofile(38): Instantiation of 'dffeas' failed. The design unit was not found.
# Time: 0 ps Iteration: 0 Instance: /top/ttx/ddio_out/loop0(0)/ddio_outa/inst File: nofile
# Searched libraries:
# C:/Users/alphatec/Desktop/test_sim/lvds_tx2/simulation/modelsim/rtl_work
Thanks for helping
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    1. We have tried to simulate LVDS soft IP on MAX10 FPGA for both receiver and transmitter configuration with other setting being default which worked fine. Attached respective image and Modelsim transcript.
    2. Used Quartus STD 17.0 & Modelsim 10.5b SE.
    Try to regenerate the IP and simulate with appropriate modelsim version based on Quartus version used.
    • Can you give more info on Tools used?
    Anand Raj Shankar
  • AAlph's avatar
    AAlph
    Thank you for your response.
    I tried to regenerate the IP but i got the same problem.
    I'm using Quartus prime lite 18.0.0 and ModelSim - INTEL FPGA STARTER EDITION 10.5b.
    the settings of the generated IP are:
    single supply
    mode TX
    3 channels
    serdes factor 10
    external PLL
    Best Regards.
    AnandRaj_S_Intel
    H​I,
    Tried to simulate the IP generated using Quartus 18 lite and Modelsim SE 10.5b.
    Not succeeded in producing the error.
    But error was replicated on modelsim 10.6c.
    Attached transcript and image.
    1. Reinstall Modelsim from below link and try.
    http://fpgasoftware.intel.com/18.0/?edition=lite
    Anand Raj Shankar
  • Hi,
    We acknowledge this issue. Anand as our L1 engineer has replicated this issue and we've posted this in our internal defect database.
    Currently, we are in the sighting stage. If there is any progress, I'll let you know.
    Joseph
    Intel Customer Support
    Sales Marketing Group
  • AAlph's avatar
    AAlph
    Hi , and thank you again for your response
    unfortunately the reinstallation of modelsim didn't resolve the ptoblème .
    Best regards.
  • Hi,
    Thanks for continuing provide us your test result. We will revert back this message to our engineering team.
    Joseph
  • Hi,
    Just to let you know we are still working internally with our engineering team. It takes a while for the routing and will keep you posted once we get an updates.
    Joseph
  • FMors's avatar
    FMors
    I have the same error using Quartus Prime 18.1.0 Build 625 9/12/2018 SJ Lite version
    and
    ModelSim - INTEL FPGA STARTER EDITION 10.5b Revision: 2016.10 Date: Oct 5 2016.
    Device: Cyclone10 as on Arduino VIDOR4000 board to be used for students.
    Circuit: a simple 7-bit counter.
    Log transcript on Modelsim:
    # vsim -gui -l msim_transcript -L cyclone10lp_ver -L work testbench
    # Start time: 12:07:41 on Jan 06,2019
    # Loading work.testbench
    # Loading work.prove_project
    # Loading cyclone10lp_ver.cyclone10lp_io_obuf
    # Loading cyclone10lp_ver.cyclone10lp_io_ibuf
    # Loading cyclone10lp_ver.cyclone10lp_lcell_comb
    # ** Error: (vsim-3033) prove_project.vo(1998): Instantiation of 'dffeas' failed. The design unit was not found.
    # Time: 0 ps Iteration: 0 Instance: /testbench/pproj File: prove_project.vo
    # C:/intelFPGA/18.1/modelsim_ase/altera/verilog/cyclone10lp
    # D:/PROGETTI/ARDUINO/Vidor4000/projects/prova/simulation/modelsim/gate_work
    Thanks for the help.
    Fabio
