lzago's avatar
lzago
1 month ago
SerialLite II license for Arria10 FPGA
I purchased a SerialLite II license and received the license file. However, I need a special license to support Arria 10 FPGAs. In previous years, I obtained this license by contacting Altera technical support through a sales representative. This year, I was advised to contact Altera through the forum. Please help me find the correct way to obtain the necessary license file.
  • lzago's avatar
    lzago
    OK,
    In that case, I still have to wait a little longer
    Lech
  • lzago's avatar
    lzago
    Have you found a solution to my problem?
    Lech
    • paveetirrasrie_Altera's avatar
      Hello Lech,
      Apologies for the delayed response.
      The request is currently pending internal approval. I’ve followed up on it and will ensure that you receive the license once the approval is granted.
      Pavee
      • lzago's avatar
        lzago
        Thank you for the new license file.
        I made some tests.
        1/ Copied complete your license instead of previous SeliatLite license.
        Quartus  gives the error:
        Error (292027): Specified license does not contain information required to run the Quartus Prime software.
        2/ Copied only following lines your license instead of previous SeliatLite license.\:
        FEATURE 6AF7_00AD alterad 9999.12 31-may-2027 1 BDCA93F6AAED \
               VENDOR_STRING="99999999hdLkhVVVVVVVVUPDuiqqqqqqqq11X38oooooooopjz5crrrrrrrrtmGzG88888888bqIh0ppppppppgYYWizzzzzzzzbp0FV88888888BUEak88888888D2FFRCCCCCCCCWL$84" \
               SIGN="0956 438C DA09 1931 5061 C004 1B03 4B08 3F11 AD37 F38F \
               E2C2 BF8C 9D96 0F24 111F A8E4 3089 F835 84EA 3F9B 9AE4 7A3E \
               CCB3 1BDB 971F 76EA A70C 3B97 6E12"
        The error message is:
        Warning (292000): FLEXlm software error: No SERVER lines in license file. Feature:       6AF7_00AD License path:  C:\Users\PC COMPUTER\LINS\Altera\LR-158764_License_2026.dat; FlexNet Licensing error:-13,128 For further information, refer to the FlexNet Licensing documentation, available at "www.flexerasoftware.com"..
        Error (10003): Can't open encrypted VHDL or Verilog HDL file "D:/AADirectory/A_PROJEKTY/CONS_EL/SMAG/DSAM400_ADCU_NDL/source/HSL_STREAM/SL2_STREAM/IP/SL2_MU_slite2_top.v" -- current license file does not contain a valid license for encrypted file
        The firmware is originally written and compiled with Quartus 16.1
        So, please help me solve the problem
        Lech
  • Hello Lech,
    Good day.
    Kindly allow me 1-2 days. I will get the right contact person to help you with this request.
    Pavee
    • lzago's avatar
      lzago
      OK, thanks.
      Lech
