SerialLite II license for Arria10 FPGA
Have you found a solution to my problem?
Lech
- paveetirrasrie_Altera5 months ago
Hello Lech,
Apologies for the delayed response.
The request is currently pending internal approval. I’ve followed up on it and will ensure that you receive the license once the approval is granted.
Pavee
- lzago5 months ago
Thank you for the new license file.
I made some tests.
1/ Copied complete your license instead of previous SeliatLite license.
Quartus gives the error:
Error (292027): Specified license does not contain information required to run the Quartus Prime software.
2/ Copied only following lines your license instead of previous SeliatLite license.\:
FEATURE 6AF7_00AD alterad 9999.12 31-may-2027 1 BDCA93F6AAED \
VENDOR_STRING="99999999hdLkhVVVVVVVVUPDuiqqqqqqqq11X38oooooooopjz5crrrrrrrrtmGzG88888888bqIh0ppppppppgYYWizzzzzzzzbp0FV88888888BUEak88888888D2FFRCCCCCCCCWL$84" \
SIGN="0956 438C DA09 1931 5061 C004 1B03 4B08 3F11 AD37 F38F \
E2C2 BF8C 9D96 0F24 111F A8E4 3089 F835 84EA 3F9B 9AE4 7A3E \
CCB3 1BDB 971F 76EA A70C 3B97 6E12"
The error message is:
Warning (292000): FLEXlm software error: No SERVER lines in license file. Feature: 6AF7_00AD License path: C:\Users\PC COMPUTER\LINS\Altera\LR-158764_License_2026.dat; FlexNet Licensing error:-13,128 For further information, refer to the FlexNet Licensing documentation, available at "www.flexerasoftware.com"..
Error (10003): Can't open encrypted VHDL or Verilog HDL file "D:/AADirectory/A_PROJEKTY/CONS_EL/SMAG/DSAM400_ADCU_NDL/source/HSL_STREAM/SL2_STREAM/IP/SL2_MU_slite2_top.v" -- current license file does not contain a valid license for encrypted file
The firmware is originally written and compiled with Quartus 16.1So, please help me solve the problem
Lech
Hello Lech,
I'm currently investigating the issue with licensing team. Please allow me a day or two. I'll get back to you with an update.
Pavee
