What family are you targeting?
The high-performance core should run the fastest(it re-calibrates it's receive path to align with the data). The Microtronix has some very nice multi-port features that I've seen people want. That's probably the biggest trade-off. (The Altera core has one port, and you need to do your own muxing if multiple components are accessing it. SOPC Builder can do this for you, but it's all pretty direct.) For the ease of use, I've seen people use both and have no problems and say it was really easy. But when something goes wrong, I've seen people struggle with both, so the bottom line is that it depends. I'm not sure about the other two questions... - Altera_Forum
Hi Rysc,
Thanks for a prompt response. I use Cyclone III (the C120 speed grade 7). There are about 7 masters which connect to a single SDRAM controller. Need more ideas. Thanks - Altera_Forum
Does Microtronix support the size and speed of memory you want to interface to? Do they support 7 ports(not that you couldn't expand some of the ports). Your 7 masters are going to have some system requirements that you need to understand(one may need low-latency, one may need priority, one may need large on-chip buffers, one may not need anything but to stay out of the way, etc.). I would compare that to what Microtronix offers, and maybe give them a call to discuss.
You also may want to describe your requirements and post to niosforum, as you'll probably get better responses on how SOPC builder adaptors and the avalon interconnect can help your system(I'm a novice on the SOPC stuff). Of course, hopefully others on this forum reply too. - Altera_Forum
I do not have experience with the Microtronix version of the controller. However, the Altera High Performance controller has been very easy to use. Using SOPC builder you could easily do a 7-port implementation (I've done many more than that) with little effort on your part.
Alternatively I don't expect it would take you long to come up with your own arbitration logic scheme if you were to do it outside SOPC builder. As far as performance. That depends primarily on how efficiently you access the SDRAM. I have at times achieved up to 95% efficiency on the Altera controller. Jake - Altera_Forum
--- Quote Start --- Does Microtronix support the size and speed of memory you want to interface to? Do they support 7 ports(not that you couldn't expand some of the ports). Your 7 masters are going to have some system requirements that you need to understand(one may need low-latency, one may need priority, one may need large on-chip buffers, one may not need anything but to stay out of the way, etc.). I would compare that to what Microtronix offers, and maybe give them a call to discuss. You also may want to describe your requirements and post to niosforum, as you'll probably get better responses on how SOPC builder adaptors and the avalon interconnect can help your system(I'm a novice on the SOPC stuff). Of course, hopefully others on this forum reply too. --- Quote End --- Thanks Rysc. I appreciate your replies very much. There is no problem with the size and speed of the DDR2 I am going to use. The Microtronix's support up to 6 ports, 2 of them will be used for the Nios 2 processor (instruction, data) which is expected to consume a little bandwidth (around 5% of the DDR2's peak bandwidth.) The 4 ports remained will be shared between 7 masters which are expected to consume 40% of the DDR2's peak bandwidth. These kind of connections should be easily done by the SOPC builder. The 7 masters are: - a write/read master for 720x480x24bit @ 60 fps video buffering (let label write m1, read m2) - a write/read master for 1920x1080x24bit @ 60 fps video buffering (let label write m3, read m4) - 2 read masters for 640x480x24bit @ 60 fps video reading (let label them m5 and m6) - a read master for 800x480x24bit @ 60 fps video reading (let label it m7) m1 to m4 are masters of encrypted IPs which I do not understand well how they are scheduled. m5 to m7 are created by myself so I can fully control them. These 7 master should have the same priority. I have to somehow control the overall system scheduling. I don't have an idea of how to do right now. Please advice if you have experience dealing with time sharing systems. I may post to Nios forums to direct gurus there to this thread. Thanks for reminding me of a very good resource. - Altera_Forum
--- Quote Start --- I do not have experience with the Microtronix version of the controller. However, the Altera High Performance controller has been very easy to use. Using SOPC builder you could easily do a 7-port implementation (I've done many more than that) with little effort on your part. Alternatively I don't expect it would take you long to come up with your own arbitration logic scheme if you were to do it outside SOPC builder. As far as performance. That depends primarily on how efficiently you access the SDRAM. I have at times achieved up to 95% efficiency on the Altera controller. Jake --- Quote End --- Hi Jake, I am considering arbitrating the masters myself but I have no experience with this kind of task. Would you please tell me more about your experience? How did you share the bandwidth between masters to achieve the system performance and function. Mine is a video processing system from/into which video data is streamed. Looking forward to hearing from you. - Altera_Forum
I currently have a design that uses 8 Avalon masters and is a video application. The design performs video frame buffering for 4 video feeds. Each of the video feeds can vary in input format between 720x480@60fps to 1920x1080@60fps.
There are two issues at hand: 1 - You need to dedicate enough time to each master to allow efficient access of the DDR2 memory. If you just write small chunks of data and constantly switch between masters, your DDR2 efficiency will suffer and you won't be able to satisfy your bandwidth requirements. This is due to the memory controller having to switch between pages within the memory. 2 - You need to provide enough local buffering on each of the masters so that they don't overflow or underflow while the other masters are accessing the memory. I have done this three different ways: 1 - SOPC builder allows you to specify priority and arbitration shares for each of the masters. You can use this to ensure that each master is guaranteed a certain number of accesses on the bus (assuming the master needs them). 2 - You can create your avalon masters to support bursts. When using bursts, the master specifies how many transfers it wishes to make. No other masters are granted access during that time. 3 - You can create your own arbitration. Mine is quite simplistic. Round Robin scheduling between the masters. Each master is guaranteed a minimum amount of transfers unless it doesn't actually need them. If none of the other masters have something to say, a master may continue to occupy the bus. This is somewhat self regulating as the DDR2 access becomes more efficient as the loading increases. The local buffering of course is usually done using FIFOs. One thing you need to do is ensure that your data transfers take full advantage of the width of your memory interface. Do not do 32-bit data transfers if your DDR2 memory is 128 bits wide. You're just killing your efficiency otherwise. Your most inefficient accesses will be your NIOS master. Give it as large of a data cache as possible. Consider using other memory for the NIOS rather than your buffering memory. Don't know if this helps but good luck. Jake - Altera_Forum
Hi Jake,
Sorry for my belated reply. --- Quote Start --- There are two issues at hand: 1 - You need to dedicate enough time to each master to allow efficient access of the DDR2 memory. If you just write small chunks of data and constantly switch between masters, your DDR2 efficiency will suffer and you won't be able to satisfy your bandwidth requirements. This is due to the memory controller having to switch between pages within the memory. 2 - You need to provide enough local buffering on each of the masters so that they don't overflow or underflow while the other masters are accessing the memory. --- Quote End --- How did you deal with the issue no.2? I don't have other memory resources except for a single DDR2 and FPGA on-chip memory. On-chip memory is the only option for local buffering in my case. --- Quote Start --- I have done this three different ways: 1 - SOPC builder allows you to specify priority and arbitration shares for each of the masters. You can use this to ensure that each master is guaranteed a certain number of accesses on the bus (assuming the master needs them). 2 - You can create your avalon masters to support bursts. When using bursts, the master specifies how many transfers it wishes to make. No other masters are granted access during that time. 3 - You can create your own arbitration. Mine is quite simplistic. Round Robin scheduling between the masters. Each master is guaranteed a minimum amount of transfers unless it doesn't actually need them. If none of the other masters have something to say, a master may continue to occupy the bus. This is somewhat self regulating as the DDR2 access becomes more efficient as the loading increases. --- Quote End --- I will try one after another. This is the first time I heard about 'priority and arbitration shares' between masters within the SOPC builder. Although it's self-explanatory, I will read the SOPC builder handbook... There is a customizable scheduler comes with the Microtronix SDRAM controller. Its default arbitration scheme is Round-Robin. The Microtronix's is becoming my choice provided that it's easy to simulate before being implemented into a real hardware. --- Quote Start --- The local buffering of course is usually done using FIFOs. One thing you need to do is ensure that your data transfers take full advantage of the width of your memory interface. Do not do 32-bit data transfers if your DDR2 memory is 128 bits wide. You're just killing your efficiency otherwise. Your most inefficient accesses will be your NIOS master. Give it as large of a data cache as possible. Consider using other memory for the NIOS rather than your buffering memory. --- Quote End --- Related to my first question in this post, what memory resources do the FIFOs utilitize: external resources or FPGA on-chip resources (on-chip memory, FPGA LEs, etc.)? I am considering creating burst masters with data width of 128 while the DDR2 is 64 bit wide. About the Nios, I might have to use on-chip memory. The biggest issue here is that there may be not enough on-chip mem. for both masters local buffering and Nios's program memory. --- Quote Start --- Don't know if this helps but good luck. --- Quote End --- I don't have enough words to say THANK YOU. I was relieved to hear from you. Avtx30 - Altera_Forum
Yes the FIFO's are usually created with onchip memory. Typically in a hefty video processing application, onchip memory and DSP blocks become precious items. They are usually the limiting factor in the design rather than logic resources.
Jake - Altera_Forum
Thanks Jake and Rysc. I will be back.
