17 years agoSDRAM controller: Altera High Performance vs. Microtronix Multi-Port
We are in a process of choosing which one to use: the Altera High Performance SDRAM controller or the Microtronix Avalon Multi-Port SDRAM controller. Please advice, in the following factors: ...
17 years agoI currently have a design that uses 8 Avalon masters and is a video application. The design performs video frame buffering for 4 video feeds. Each of the video feeds can vary in input format between 720x480@60fps to 1920x1080@60fps.
There are two issues at hand: 1 - You need to dedicate enough time to each master to allow efficient access of the DDR2 memory. If you just write small chunks of data and constantly switch between masters, your DDR2 efficiency will suffer and you won't be able to satisfy your bandwidth requirements. This is due to the memory controller having to switch between pages within the memory. 2 - You need to provide enough local buffering on each of the masters so that they don't overflow or underflow while the other masters are accessing the memory. I have done this three different ways: 1 - SOPC builder allows you to specify priority and arbitration shares for each of the masters. You can use this to ensure that each master is guaranteed a certain number of accesses on the bus (assuming the master needs them). 2 - You can create your avalon masters to support bursts. When using bursts, the master specifies how many transfers it wishes to make. No other masters are granted access during that time. 3 - You can create your own arbitration. Mine is quite simplistic. Round Robin scheduling between the masters. Each master is guaranteed a minimum amount of transfers unless it doesn't actually need them. If none of the other masters have something to say, a master may continue to occupy the bus. This is somewhat self regulating as the DDR2 access becomes more efficient as the loading increases. The local buffering of course is usually done using FIFOs. One thing you need to do is ensure that your data transfers take full advantage of the width of your memory interface. Do not do 32-bit data transfers if your DDR2 memory is 128 bits wide. You're just killing your efficiency otherwise. Your most inefficient accesses will be your NIOS master. Give it as large of a data cache as possible. Consider using other memory for the NIOS rather than your buffering memory. Don't know if this helps but good luck. Jake
