14 years agoReceive Transceiver clock recovery problem without loopback
I am working on a high speed optical fiber link between two FPGAs. Now the design seems to work perfectly in a loopback setting. But when I connect two boards together, download the exact same designs on the two boards and analyze the received data with signaltap, I get something that looks like the right stream of bits but with what seems to be a messed up clock (for example every now and then there would be two 1's in a row when there should be only one of them). I am stunned that clock recovery works fine in a loopback but not in a real setting. Has anyone seen this kind of issue before? any pointers to what could be the issue?12 Replies
Problem solved!
Since the example design provided by Terasic was for the development kit, I had to change the pin assignments and clocks used to make it work with the DE4 (I did this a long time ago). In this process, the pin for the clk2_p clock was set to a 2.5V pin by default, whereas in the design it was intended to be used in LVDS mode. I changed it back to LVDS and now the LTD seems to behave more normally: It actually doesn't lock when the cables aren't connected properly (the LED indicating successful locking flickers). I imagine it worked in the loopback case because the transmitter and receiver had the exact same clock, so it wasn't a problem. But in the real case I guess that some ppm differences between the clocks made the CDR unit fail. I get another problem now though. In a simple design all 4 channels work well. But when I use a bigger design with some other transceivers, 3 of the channels work fine, channel# 0 properly sends the data, but does not receive anything (al 0's). I know it sends data properly because if I interface the big design with the small one, the small one actually receives data. Maybe it's a conflict between transceivers in the big one... ?!?! But this is not related to this topic anymore, hopefully I will find a solution soon... Thanks for your help Dave! - Altera_Forum
--- Quote Start --- Problem solved! Thanks for your help Dave! --- Quote End --- Great, and you're welcome. Cheers, Dave
