It looks like bonding is not supported at rates > 17.4G:
Also the ATX PLL refuses to configure for 20G with bonding:
Can you please help?
Thank you for your question. From your description, you are asking about the maximum data rate supported by the Stratix 10 ATX PLL when operating in bonded mode. You are correct — according to AN 778: Intel® Stratix® 10 L‑Tile/H‑Tile Transceiver Usage, channel bonding is not supported for data rates above 17.4 Gbps. We understand this may be inconvenient, and we appreciate your patience.
In parallel, I am consulting with our DisplayPort IP experts to confirm whether the DP IP can support 20 Gbps while using bonded channels. I will update you as soon as I receive a definitive response.
If you do not hear back from me by the end of next week, please feel free to ping me. Thank you.
