16 years ago
problem Master LCD of Read/write in cyclone II with vhdl
hello,
i would to create my master of read and write in LCD in the cyclone II
but before start write and read i would write the code of
Initialization of the LCD in cyclone II with VHDL.
this is the code of initilizate LCD with C
void LCD_Init()
lcd_write_cmd(LCD_16207_0_BASE,0x38);
niosleep();
lcd_write_cmd(LCD_16207_0_BASE,0x0C);
niosleep();
lcd_write_cmd(LCD_16207_0_BASE,0x01);
niosleep();
lcd_write_cmd(LCD_16207_0_BASE,0x06);
niosleep();
lcd_write_cmd(LCD_16207_0_BASE,0x80);
niosleep();
so if somebody have already this pb ?
    Hi, if I have understood, You want to write a VHDL code for Initialization of the LCD, don't you ?
    If yes, you have to design a short sequential logic (with counters in order to make temporisation) which will be a Finite State Machine, but a quite simple one.
    But where is the problem of using LCD_Init() ?
    You call LCD_init() at the begining of your main programm.
    hello,
    yes i wrote a code vhdl for initilization of LCD ,
    i send the value of initilization one after one using state machine and process
    but when i would tried in simulation or in cyclone II no result
    but if i inderstand for your reponse i can use the function lcd_init()
    in vhdl code ?
    because i would have custom IP (master of read & write ) in LCD
    Is your LCD OK ?
    I guess you use 2*16 chararacter Text LCD.
    LCD takes approx. 40 ms to "boot up".
    In your state machine, when you send init. commands, you must either wait for a time (2ms but it depends of the LCD) or for a busy signal.
    Make sure of your control signal : LCD_Rw, LCD_en...
    Make sure of your inout LCD_data bus and control signal on this.
    Make sure of your init. commands : your sequence. I have a doubt on what you are posted.
    hello,
    yes i work with The Optrex 16207 LCD in the cyclone II
    for all signal of controller LCD i attached in the top level this is
    LCD_ON <='1';
    LCD_BLON <= '1';
    component_sopc_LCD :sopc_LCD
    port map (
    LCD_E_from_the_lcd_0 => LCD_EN,
    LCD_RS_from_the_lcd_0 => LCD_RS,
    LCD_RW_from_the_lcd_0 => LCD_RW,
    LCD_data_to_and_from_the_lcd_0 =>LCD_DATA,
    i don't know if you inderstand my question is : i would create a Master who write and read in the LCD !the pb of initialzation of lcd ??
    you find a code who i wrote attached to this replyhttps://www.alteraforum.com/forum/attachment.php?attachmentid=2738
    Hi, you speak French :)
    Your English writing is not very good.
    We continue to write in English so that others can understand.
    You don't have a reset signal and/or a RAZ. i suggest you to add reset signal.
    process (reset_n, clk)
    begin
    if reset_n = '0' then
    -- all init here
    elsif rising_edge(clk) then
    -- all synchronous signal here
    end if;
    end process;
    One of good coding style is to not make Initialization in signal declarations because of synthesis tool.
    Minor : when you declare "integer", better is to specify "integer range 0 to 250" for ex.
    maybe your proc_state is not initialize to '0'
    Major : You have to be most rigorous when writing process : in line 111 (--process pour l'initialisation envoie sequentiel des données) you should write "process(g_clk)"
    Amicalement,
